Well, the thing DEFINITELY has some snap to it now!
Twin turbo 306 Towncar
Right now the recipe is pretty simple:
Stock Lincoln 5.0 block, crank, connecting rods, bored to 306
Speed Pro hyper pistons
ARP rod bolts
GT40 3 bar heads with 1.7 roller rockers and 3 angle valve job and dual valve springs <- this combo wakes it up after 4000rpms
GT40 Lower Intake
Exploder Upper intake
67mm lightning EGR spacer, 65mm TB
running stock HO cam advance 4* with 19lb injectors and Mark VII ECU with speed density, 10* of timing - 87 octane
AC and Smog pump deleted
Heater core bypassed
Warm air intake
Taurus electric fan
Rebuilt stock AOD with shift kit and B&M 2000 stall
stock 3.27 open rear end
17" wheelsLast edited by 89LincolnTWNcar; 10-08-2009, 12:24 AM.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Just got done with some reliability mods to make the twins happier... Taurus fan, 195* superstat, dual transmission coolers (one in rad, one external) Only stuff I SHOULD do before I add all that power is the BB and rear axle with discs, for safety reasons.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Ahh, update. Still amassing parts for the Big Brake upgrade and and mass air conversion. So far I have spindles, calipers & brackets, pads, rotors, and a 80mm maf. Now I just need the A9l or a9p or a9m computer from a mustang, some 92-94 upper control arms, and a good set of upper and lower balljoints and ES bushings.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
just use some simple common sence t3 flanged turbos are like camaros and mustangs a dime a dz. ide probaly find 2 t3 flanged turbos off some thing in the 2.0-2.3l range. the most common cars ive seen in junkyards are dsm's(eclipse,lazer,talions,exc) 2.3l ford turbo chickens and mustangs,saabs have a hi and lo boost t3 turbo,or for something like 150 you can get a hybrid t3/t4 chinese turbo on ebay.(i know chinese parts suck but thats what thay used on project f-bomb and that maid 890hp on 87octane@406cid.
persionaly ide probaly go with the saab turbos there probaly less likely to be driven by some kid and beaten to death.
update: mega junkyard score, somebody Cash4Clunker'd 2 foxes, a 90' and a 92' both with A9L computers. Yard here charges 43.99 for computers so I grabbed both and sold one on ebay for $120 and made my money back and got mine for free. Now all I need is the harness and the MAF conversion is on!1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Nice score.~David~
awesome.86 Lincoln Town Car (Galactica).
Just ordered the Mass-Air conversion harness off of ebay. I will start as soon as it gets here. Maybe I will do a detailed how-to with pictures for the MAF conversion on a box Town Car.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Not yet, I decided to wait until after I go to New York over spring break in mid-march.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Anabelle has been my daily driver for a while, so not much headway has been made as of yet. I do have all the parts for the MAF conversion and it should be going down here soon. I just gotta get one of my other projects rolling so I can take her down for a while.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
the junk in my sig is SD, but you are better off going maf
are you gonna run an fmu or bigger injectors?
seems like 42's and a lightning 90mm maf would the way to go, but being blow through; you'll definately need a serious tune, mail order probably wont cut it
