I used that cam you mentioned .533/.544 lift, gt40 non p heads, shorty headers, and the stock ho intake with a 65mm tb. The torque stays above 300 ft lbs from 3000-6000rpm peaking at about 330 ft lbs. If you use the mustang rpm governor which sets the shift point at 5000rpm youll make 292hp. But, if you can find an aftermarket governer (which i believe comes with the transgo hp shift kit) that will allow you to adjust the shift point to 5500-6000 rpm youll gain another 35hp. This engine seems to really like the high revs with that cam, but makes alot of torque as well. Looks like a good combo that you could have some fun with. 70torino429
__________________mind you this was a desktop dyno but wow id love to see what happens with afr185 or 165 heads yikes!!!
