HAHA CAMS AGAIN
    HAHA CAMS AGAIN
    Well I have heard that the H.O. cam is not to bad for a 302 or 351 buildup, but I was curious who sells it? and what are the differences in the SD cam MASS Air cam and the cobra cams I hear The SD is the best one really?
    The H.O. cam is generally taken from a used HO engine, like an 87(?)-95 mustang. To buy it new/aftermarket would be a bit silly, as for the price you could get a Comp or other performance brand cam that would probably yield superior results.
      If you are interested I have a 1986 flat top piston HO cam from a mustang I am selling. they are roller engines so there is no wear, unless something breaks in a horrible manner.
      1985 GMC 1500
        There is a very slight difference between speed density HO cams and mass air cams, I think its something like 10 degrees less exhaust duration on the mass air cam, but a steeper ramp rate. Net result is supposed to be a wash, but unofficially the SD cams are supposed to have a little better low rpm performance.
        The Cobra cam originally came from the 92 Tbird HO motor. It should make a little more low end torque than a regular HO cam. I'd actually like to try one in something.
        '85-'88 5.0L HO cam specs:
        lift figures directly on the cam lobe. multiply by 1.6 to get lift at the valves with stock 1.6 rockers.
        .278" intake cam lift
        .278" exhaust cam lift
        266º intake duration
        266º exhaust duration
        intake valve opens 17º BTDC
        intake valves closes 69º ABDC
        exhaust valve opens 67º BBDC
        exhaust valve closes 19º ATDC
        36º overlap
        I had the other cam specs somewhere but I can't find them now
          Thanks guys, my brothers dampner went out in his 90 GT mustang and it snapped the crank so I got two motors to build this summer on a budget, one for my vic and one for him just playing around with the explorer motors vs roller cammed 351windsors 94-98?, this will mostly be junkyard builds with upgrades down the road, so Im looking for good parts combos on the cheap to get god power from these engines.
            Oh and a long rod combo may be in the future which is why I;m looking at these milder cams btw.
              I have always been told 87-88 HO cams were 276/266 while 86, 89-95 are 266/266. dont know how much truth there is to it, but I've also always heard the 87-88 HO is the best of the bunch
              you have to change quite a few parts to go 351, not necesarily budget
              not much power from a long rod combo, by the time you buy pistons, rods, and machine work; you might as well get a crank and take the cubes from a stroker; not necesarily budget either
              but it all depends on what budget is, I've seen people get upset over $100
                Ooh! Ooh! Hey! Look at me! Wooh! Wooh!
                Have you been reading this?
                For discussions on performance modifications to the 5.0/5.8 engine. Includes engine swaps and whatever else you can think of.
                Oddly enough, I've been quietly collecting a few parts for a P-headed 351W long-rod build. I hesitate to mention anything, simply because when I do mention something, something invariable goes hideously wrong, and I end up having to start all over again. Thus having said something, I expect something else to go wrong now.
                At any rate, A dished 331 stroker piston would provide around a static 10:1 compression ratio (before the cam is figured in, so far as cylinder pressure bleedoff is concerned), and with a custom camshaft, I'm really interested in seeing where this motor could go....
                  Originally posted by jayh View Post
                  not much power from a long rod combo, by the time you buy pistons, rods, and machine work; you might as well get a crank and take the cubes from a stroker.........
                  The purpose behind the long-rod motor (for me, anyway), is to make a smooth, well-rounded 351W that produces around 350-400 hp, using as many factory parts as possible. The iron-headed long-rod 351W that I built was really smooth, revved quickly, got really good gas mileage, and pulled everywhere. If I wish to stick with the factory IRS in my T-bird, without having to do too many mods to it, this would be the perfect engine for the car, especially if I stick with the AOD layout. The 408 would be a better choice, but I'm a spoiled sissy who enjoys a smooth yet somewhat-frightening car to drive....and I would like to try to do it with a $60 set of P heads.
                    Right my thoughts as well, I had read a long rod article a few years back on an EFI 351w, but with all the strokers these days had forgotten untill I started reading up on your info, I also am looking to get 350-400 hp with factory parts without reving it to the moon.
