Is there any difference between Fox headers and SN95's? I was thinking they might be very slightly more suited because the SN95s have an inch or so longer wheelbase.
Long tube headers
Originally posted by CheeseSteakJim View PostIs there any difference between Fox headers and SN95's? I was thinking they might be very slightly more suited because the SN95s have an inch or so longer wheelbase.
Also, I'm pretty sure SN95s came stock with the later mini-starter ... not that that's a big deal once you're paying for real headers. I might have had better luck with my attempt if I hadn't been quite so cheap.
Incidentally, as Mr. Land Yacht learned, ALWAYS make sure the headers fit on YOUR car. He had someone modify a set to fit using someone else's car as a template, and when he went to actually install them, they still didn't fit.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostBut is the orientation between the engine and the K-member any different? What about other obstacles Fox headers are designed to clear that are in different places on Panthers? If I were to try longtubes again (and I hope to do so), my inclination would be to start with the cheapest Fox longtube I can find and cut and hack till it fits. The set I had in my possession for a couple of weeks, I recall the main interference being between the starter and framerail, though admittedly I never actually tried the d/s header when the p/s wouldn't even go into place.
Incidentally, as Mr. Land Yacht learned, ALWAYS make sure the headers fit on YOUR car. He had someone modify a set to fit using someone else's car as a template, and when he went to actually install them, they still didn't fit.http://secondhandracing.com/Home.aspx
Yours are mid length aren't they?1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
Originally posted by Pesty351 View PostYours are mid length aren't they?http://secondhandracing.com/Home.aspx
