i gots cherry bombs on the lincoln. ill tell you, they arnt loud at all with cats. iv had mine on the lincoln for a few years and just last year they have gotten louder since the pcking has broken down.
had 31 inch thrush glasspacks sounded ok, much better than my turbos mufflers i have now the drone is killing me lol. i should have stayed with my glasspacks lol
smitty's, tryed them, they seem to be better quaility than cherry bombs(way heavier in weight also) deeper sounding. One more option; straight pipe stuffed with 5/16 or 1/4 inch chain link as very unique sound.
Unless you're catless, you don't really get the full effect of a glasspack.
I think the Patriots are the same as the 'Smittys'. They seem to be the best quality.
Cherry Bomb exhaust parts aren't that great quality wqise. I have a Cherry Bomb Extreme on my truck, and it sounds great, but it isn't holding up too well.
**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser **2006 MGM,"Ultimate": 4.6/ 2.73/ Dark Tint, Magnaflows, 19s, 115K Daily Driver **2012 Harley Davidson Wide Glide (FXDWG):103/ Cobra Speedsters/ Cosmetics, 9K Poseur HD Rider **1976 Ford F-150 4WD: 360, 4 spd, 3.50s, factory A/C, 4" lift, Bilsteins, US Indy Mags, 35s Truck Duties
to think of it, go with a straight copper exhaust! lol it will sound like an old boat
Does the lopo engine drastically cut down on the poppy/snappy sounds?
It just doesn't have the rpm there and you have to remember there are 4 cats on it. I personally don't like the popping sound, just the rumble. I know you will see a difference after a few thousand miles when the mufflers break in. I have straight through Magnaflow xl turbos and they are not all that loud. I have duals and my dad has a single on his GMC 1500 and that 305 is twice as loud as my car. It really depends. I would swap to 2 high flow cats.
"Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles 1985 GMC 1500
Now that I'm thinking about it; what would be the best glasspack (or other type of muffler) to use when trying to quiet-down a semi loud exhaust? I got BBK shorties, BBK cat'd H-pipe, and Summit Turbos. I would replace the mufflers, but I don't feel like removing and replacing perfectly good turbo muffs.
I have straight pipes on my 5.0 and it doesn't START to get hairy (the "pop" sound you seek) until 2500 revs. When you make peak torque at 2000, you don't get up to that pop too often when there are other vehicles around. This has been my experience, anyway, and I could be way off. I don't have glasspacks.
longest ones you can get that will fit back there under the trunk......think i used 21" on the superlincoln
Ahh, yes. Those two upper cats were removed 1-2 years after puchasing the car used with 72K on it. Knocked around like golf balls. The garage welded pipe from both manifolds to the 3-way cats. See attached pictures:
1) Left manifold flange/weld to..#2
2) Left flange extension to left 3-way, O2 injected cat
1987 Mercury Grand Marquis LS 2DR
302CID, K&N air filter, Dual cherrybomb glasspacks, Vogue tyres (Front:P225/60R16,,Rear:P235/60R16), Centerline Pulsar wheels (Front:7", Rear 8")
COBRA 25LTD CB with/ Wilson 500 whip antenna.
