Update: Got my lightning EGR..just need to trade the mine with the 70mm that Scott Has That will be one thing off my list.
5.8 Swap in the works, questions.
Bringing this back lol.
Granted I haven't been able to measure the TFS intake (this build has been put on hold for a while. but I am getting a few parts), but if for some reason it doesn't fit under the stock hood, would there be enough clearance between the cross member and the oil pan to fab up some motor mounts that would drop the engine, say an inch?Parts Car (Scrapped ) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
if you used solid mounts. Not sure that rubber mounts would be able to keep the engine from tapping the cross member. I think there's only just over an inch of clearance at the oil pan to begin with.
I havent read this in a while.
a tfs351 intake and a gt40/lightning are alot different. you might want to consider edelbrock or proproducts if the tfs doesnt work out
xe258 is gonna be dinky in a 351; with that combo, if want a comp cam, you probably want an xe270 on a 114
I've been interested in Lunati 55123LUN. I'm still curious about the TFS stage 1 cam as well. There was a Comp Cams grind in one of my catalogs that I was looking at, but I can't find the issue. It might be the one that JayH suggested.
Originally posted by P72Ford View Post8 psi is for kids. With a good bottom end, you'll be good for twice that.
A 302 with P heads is capable of pushing a CV into the 12s with 8psi of boost. Not exactly just for kids...Last edited by Mercracer; 08-10-2010, 02:59 PM.
What's the part number on the XR270?
EDIT: Nevermind found it on camquest
EDIT AGAIN: I found it on Comp's Website:
Edelbrock is the most respected name in performance! Since 1938, Edelbrock has manufactured its core products in the USA for quality and performance.
It says not for motors that came with a hydraulic roller, and not for EFI. If I do a 95 F150 Block running EFI, wouldn't that eliminate that? Or am I missing somthing?Last edited by hemihotrod402; 08-12-2010, 05:36 PM.Parts Car (Scrapped ) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
that is a retrofit/reduced base circle cam, not the one you want
its this cam-
but there is or at least was 2 versions, a 112 and a 114, the 114 might suit you better
I would look for this used, new price, you can go custom for another $22
Originally posted by jayh View Postthat is a retrofit/reduced base circle cam, not the one you want
its this cam-
I would look for this used, new price, you can go custom for another $22Parts Car (Scrapped ) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
Originally posted by Mercracer View PostYou do realize that boost is merely resistence to flow....right? Boost alone is not a valid measure of power increase. You can make stupid power with 8psi of boost.
Measured boost pressure is actually quite worthless in determining the improved power output without supporting information. Pressure gradient means very little in regards to how much air you are actually moving if you don't also know things like the volumetric flow rate (and/ or mass flow rate and fluid density), the geometry of the cross section you are flowing through, state of the fluid you are moving, and a possible host of other attributes. While these are text book terms, they apply to the conversation in the respect that if you know about the engine's capabilities regarding camshaft, cylinder head, intake, etc selection, you will have a better idea of what 8 psi will do for you.
On a stock engine, 8 psi may net you a 25% increase in power. With better heads, proper cam selection, etc, you may see a 35%+ gain simply due to the fact that the engine is capable of "using" alot more volume of air at 8 psi than a stock engine.
There many, many variables to consider to make a totally accurate conjecture regarding the power you will make at a given boost.
I think alot of times, though, tossing out a boost value gives folks a general idea of whats going on, if they know some other basic details of your set-up. Its kind of like using horespower as a way to estimate a car's performance. The number's really aren't that useful without supporting information regarding the vehicle.
Depending on who you talk to, I may or may not have a decent understanding of fluid mechanics.
Originally posted by Mercracer View Post8psi can give you a 40% or higher gain in horsepower with a properly tuned system.
A 302 with P heads is capable of pushing a CV into the 12s with 8psi of boost. Not exactly just for kids...**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
no generally 8#'s will give you a 40% gain. it is a generic formula, but its ball park
a pulley configuration that makes 8psi on a 225hp HO might only make 6psi on a 350hp combo
but ballpark 8#'s on a 225hp motor will make 315hp; 8psi on a 350hp motor(h/c/i) will make approximately 490hp
but boost is just back pressure; efficiency of the compressor, heat of the charge, and the ability of the motor to move air on its own, are all factors
Originally posted by jayh View Postno generally 8#'s will give you a 40% gain. it is a generic formula, but its ball park
And I believe I mentioned the fact that with better components, the engine will "use" more air, which means the blower will not be able to compress the air to the same pressure, thus a lower boost value.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
And I believe I mentioned the fact that with better components, the engine will "use" more air, which means the blower will not be able to compress the air to the same pressure, thus a lower boost value.86 Lincoln Town Car (Galactica).
You got it.
Ninja edit : Speaking of psi lol. One of my buddies has a cummins pulling truck. Its a first gen body with a 12 valve from a second gen. With compound turbo's. Completely built top to bottom. He revs it to 6,000 rpm when he is pulling. Anyway we had it on the dyno about a month ago, only made the runs to 5,000rpm instead of 6K, It mad 595rwhp and 1,000+ ftlbs IDK how much over the dyno only went to 1,000. The reason for the story he was making 95 lbs of boost on the dyno. He has a 100 lb gauge and he said he maxes it out when he is pulling lol.
Sorry for the OT but I figured I would share lol.Last edited by 1980c10; 08-13-2010, 07:25 PM.
'90 LX 5.0 mustang
Big plans
