Summit racing has one Holley 12-803BP $70, but there may be others out there.
302 carb..help me out
NA-15.78@91.21, 80hp shot-14.48@96.21
I noticed from your picks that you reinstalled the TFI distributor, will this cause an issue since a signal is no longer coming from the TPS to tell the computer to advance or retard the timing? I plan on using a vacuum advance distributor (duraspark II) to avoid any electronic issues caused by retaining the EEC-IV ignition components.
Originally posted by Smokestacklightnin View PostI noticed from your picks that you reinstalled the TFI distributor, will this cause an issue since a signal is no longer coming from the TPS to tell the computer to advance or retard the timing? I plan on using a vacuum advance distributor (duraspark II) to avoid any electronic issues caused by retaining the EEC-IV ignition components.
Re the flooding, I imagine Edelbrock would say that's all but guaranteed to happen with the fuel pressure at 15 psi. I second the question of making sure of exactly which bypass regulator you're using - very important that it's designed to function correctly at about 5 psi.2012 Mazda5 Touring | Finally working on the LTD again!
