Originally posted by 89crownlx
View Post
The duration is excessive for what you want to do. My recommendation is for a Trick Flow Stage 1 cam. http://www.trickflow.com/partdetail....t=TFS-51402000 A healthy idle without bad manners. It is superior to the Ford Racing alphabet cams. The lift at the valve is .499/510 which works with most pistons. The advertised duration is listed as 283/291 but I have the actual cam card in front of me and it is listed as 275/279. Looks like some marketing games are going on. That is why you should look at lift @ .050 when comparing cams. Otherwise the numbers can easily be skewed depending on how they measure the duration.
If you want to really turn it on, bolt a set of the Crane "Cobra" 1.7 rockers and your lift will jump to a bit over .540. This cam with GT40 heads on a 302 is good enough to put a Crown Vic into the low 14s/high 13s without much trouble providing the rest of the package is up to the job.
