doing GT40P swap soon... questions
    Explorers use the same thermostat and PCV valve that your stock engine uses. Retain the stock thermostat housing, and you're good to go.
      sweet, i snagged a housing off a junk car so i can assemble it and the thermostat outside the car...thanks
