Gears knocked 0.7 off the e.t. For me and 0.2 off the 60ft. But the exhaust had no effect on the 60ft. I want this crap pile to 60ft so bad I can taste it, but then both my cars died Arther same time and forced me to spend my convertor and valve body money on towing bills and fixing the marq so I would have somethingto drive arrg lol.
Ideas to lose weight and look stock
Originally posted by 1980c10 View PostGears knocked 0.7 off the e.t. For me and 0.2 off the 60ft. But the exhaust had no effect on the 60ft. I want this crap pile to 60ft so bad I can taste it, but then both my cars died Arther same time and forced me to spend my convertor and valve body money on towing bills and fixing the marq so I would have somethingto drive arrg lol.
Of course not, from stop to the 60ft you are at a low RPM, and the exhaust isn't going to give any low end gains.
I dropped .3 going to a full 2.5" exhaust on a lopo, which dropped me to 16.03. The next mod was the HO conversion (well, heads, cam, injectors, and matching ecm) which dropped .5 and got me down to 15.45.
2200rpm stall, 3.73s, no ac, no smog, weight reduction, 26" tires.
The best 60ft that car EVER pulled was a 2.18
For a good 60 you need lots of torque, good gears- and not much weight to try and move.
Pulling as much of the sound deadening out will save a good amount. Manual seat tracks, bumper supports.... Surprisingly the sound deadening removal didn't make my car much louder at all.Builder/Owner of Badass Panther Wagons
Originally posted by 1987cp View PostMe, I've been interested for a couple of years now in how much weight could be saved by fiddling with the rear door on a wagon. Sure, the extra rear side glass and stuff has some weight that make a wagon heavier than its equivalently-equipped sedan counterpart, but that door is HEAVY, and I figure it probably doesn't really have to be.
your 10.3 in the eighth means you should run about a 16.07 in the quarter.
a stock new edge mustang gt will run high 13's in the quarter with a good driver.
you need a bottle and be able to launch well.Last edited by rick99601; 10-02-2010, 12:45 AM.1988 MGM GS - Preferred Equipment Package 172A; InstaClear
1994 MGM GS Montigua
2002 Mustang GT Coupe
No, these car just need gears, alot of converter, and a nice tranny to make them boogie at the strip. IMO of course. I believe my car will drop 0.5 or better with a good converter and a nice valve body.
'90 LX 5.0 mustang
Big plans
The stock trans shifts at 4200 in an unmodified state. The stock AOD behind an HO had a different governer which got you about 4800 before it shifted. Those 600 odd rpm do cost you some speed since the HO motor still makes power at that rpm.86 Lincoln Town Car (Galactica).
what time are you h.o. guys running in the quarter?1988 MGM GS - Preferred Equipment Package 172A; InstaClear
Ditch that front sway bar at the track for better weight transfer and less weight. Bring gas cans and only put in enough gas for one run. Gallon of gas weighs 3-5 pounds or something. You could ice down the intake between runs. Dueceanahalf's bumper mods are bitchin... Aluminum radiator weighs less. Air down the tires in the back, pump em up in the front.
Originally posted by ford man View PostDitch that front sway bar at the track for better weight transfer and less weight. Bring gas cans and only put in enough gas for one run. Gallon of gas weighs 3-5 pounds or something. You could ice down the intake between runs. Dueceanahalf's bumper mods are bitchin... Aluminum radiator weighs less. Air down the tires in the back, pump em up in the front.2012 Mazda5 Touring | Finally working on the LTD again!
