"toss the elbow. Take the Explorer throttle body and grind on the shaft where it goes through the lever until the "mushroom" is gone and you can pop the lever off. Do the same with your stock throttle body. Install the stock throttle body lever onto the Explorer piece and tack weld it together. Done."
It gets no easier, just put a wet rag around the spring to slow the heat transfer so that the plastic is melted to a minimum if any. Has anyone noticed that the coolant side of a lopo egr plate has more of a sealing surface than the rear does? So its safe to bore the EGR plate to 63mm with a slight taper which in turn will fit fine to a 65mm Explorer TB, just be sure to get a Explorer TB to EGR plate gasket and use "The Right Stuff" to make sure you have no future leaks. As far as the EGR to plenum gasket sealing goes, what I did was bought a stock mustang gt gasket and took a dremel tool to the inside diameter of it because it has a metal core and bored it out to 65mm. No leaks thus far.
