Originally posted by merc91
View Post
My motor has a riddle for ya's...head issues...
I had originally torqued the long bolts down to 75 with the moly paste they supplied and I was hoping to see that they loosened a little after heat cycles but no dice, all clicked at 75 lbs still so the heads are comming off in 2 weeks, and while i'm at it I might try my luck with the comp xe-258 cam and some new valve springs.Finally have an on the books porting/custom fab business!
Originally posted by merc91 View PostI had originally torqued the long bolts down to 75 with the moly paste they supplied and I was hoping to see that they loosened a little after heat cycles but no dice, all clicked at 75 lbs still so the heads are comming off in 2 weeks, and while i'm at it I might try my luck with the comp xe-258 cam and some new valve springs.
My new ported GT40P heads and comp springs will be in next week allong with the comp xe258 and ford racing 1.6 roller rockers. Throwing it all on that week.Finally have an on the books porting/custom fab business!
bought new heads?sigpic
yeh new heads, I've had enough screwing around swapping head gaskets and doing rebuilds trying to find the problem which is probly a crack so i'm buying a set from promar engine so i'm guarenteed a great set of problem free heads to slap on. Could be the current "P" heads just need re-surfacing even though they checked out fine for warpage, or a small crack repair...if a shop can make them check out i'll sell em I guess with my 1.7 RR's.
I have seen enough hype about this 258XE cam so I guess someone's gotta see how it works or fits with the PTV clearances... So i'm going to give it a whirl.Finally have an on the books porting/custom fab business!
if a shop can work some magic and guarantee they'll work....you got a sale.sigpic
