exploder heads/intake without egr and smog
    Originally posted by mcninetyone View Post
    WOW, just goes to show you this Explorer stuff comes in everyway possible.
    If I had to do a second swap I would definitely check the heads before assuming anything!!! Thanks for the 'heads up' on that!
    Hahaha! Head puns. The best way to tell is if you have a '96 or a '98 or newer. Then there's no doubt in my mind of what heads it had.
      my bro and I both used tfs 1 cams...that's the best off the shelf cam on the planet I swear....the torque curve on the dyno was amazing....FULL torque came on just RIGHT after idle...like 1100 rpms or so and stayed flat lined all the way to 5850 rpms....but the cam had great top end too....kept pulling way past where the old HO cam would quit.
      -1999 P71 Crown vic X LAPD..
      -1966 mustang, 5.0 roller crate motor, t5 etc
      -1972 maverick 5.0 roller crate motor with EFI and a Lentech AOD
        Why do people insist on eliminating the EGR system? It makes the combustion chambers cooler, to lower NOx emissions yes, but by doing this it also lessens the chances of detonation/preignition/pinging.
        well, because my EGR system is busted and I don't want to replace it It wouldn't really matter if I was throwing enough money at it to upgrade h/c/i, though.
          How is it busted?
            i have seen some 97 explorers with gt40 heads, the easiest way to tell is to count the bars on the head gt40 are 3 bar and the gt40p are 4 bar.
            it is a little bit of an odd angle but you an get an arm back there and feel the bars and count them.
              Originally posted by v8only View Post
              I've seen some crazy stuff come out of those years...I read about a guy having the worst problem with his 96 "gt40" heads...after much research he found it was stamped with 3 bars, and had the "gt" logo on it, but had the gt40p spark plug angle that was messing him up. Go figure, a hybrid head.
              There was no hybrid head. F3ZE and F77E are the only 2 head castings you will find on an Explorer.
                it was a fuck up obviously...I know there was no hybrid...
                  1988 MGM GS - Preferred Equipment Package 172A; InstaClear
                  1994 MGM GS Montigua
                  2002 Mustang GT Coupe
                    the 97 explorer engine gabe gave me had a 12/96 production date and gt40 heads
                      My 98 exploder motor had internal egr and the spot on the #5 runner for the atc. Most of the dates on the stickers on parts were january '98. P heads. Lots of oddities through the years.
