For about the past month and half my car has been a total dog. Weather and time finally permitting I was able to get under the hood and find out what was going on. On close inspection discovered the front carb butterflies were only opening 1/2 at full throttle and prevented the secondaries from opening under full throttle. Apparently my throttle bracket had loosened causing it to shift forward. This caused the throttle cable to loose over and inch of travel. Adjusted the bracket and the tv cable, and rechecked the function. This thing is a monster once again!! Launched on the street in front of my house and one-wheeled over 100 ft before lifting (stock 3.08 open of course).
Solved my own mystery
NA-15.78@91.21, 80hp shot-14.48@96.21Tags: None
Originally posted by 86VickyLX View PostDid you get the geometry correcter for the TV?
my trans guy said i shouldnt have any problems with alignment
