If you can afford the initial cost of installation, a mild build 460 is 450+HP and low to mid 12s NA easily.... Nobody is going to use EFI 460 heads. They are better used for ballast. Early 429/460 heads are still cheap and plentiful. Even the common D3AE head will get you 450HP with little work.
Any respectable Cleveland 4V head build is over 400HP.
Most people posting do not have the cash to build a dedicated drag car and are simply hopping up their grocery getters. This is why the 351W is king. Easy bolt in with factory or easily attainable inexpensive aftermarket parts and near 400HP without even trying.
