Originally posted by Merc302
View Post
Or you could run a fuel pressure regulator and make up new lines for a bypass for the electric fuel pump.
SEFI would need different fuel lines, which could be added via compression fittings. You'd need a computer, a wiring harness from 1986-1991. an EVTM for your car and the donor car would help a lot. upper and lower intake, sensors, injectors, throttle body, tv and throttle cables. You can use your distributor from your car.
