I'm making damn sure the valve covers will fit under the intake with a 3/8" spacer before I have a machine shop do anything
roller rockers?
Originally posted by 86VickyLX View PostHave any pics of them? I'm trying to run my scorpions with my EFI, but the Ford Racing ones I have are too tall, (I can't even run the spacer required to clear the intake, because the spacer makes upper intake too high to close the hood).http://secondhandracing.com/Home.aspx
stack some nuts or washers to get 3/8" and stick that between the upper and lower intake with 2 bolts to see if the hood would close.
Milling a spacer from 1" to 3/8" is trivial with the proper machine. It would not be cost effective though. Spacers are not that expensive and if you sell the wrong spacer, you'll recoup enough money for it to not be worth the hassle.86 Lincoln Town Car (Galactica).
