and if it does leak you just bypass the damn thing.
what was issue with throttle body spacer & egr with HO?
I meant leaking exhaust gasses into the intake tract even when the EGR valve is closed, that's all I care about. It's pretty thin, but if I ever got a Lightning spacer this one would mate up with an HO intake nicely. I never installed the coolant lines to the thing, the only time exhaust is flowing in there is when EGT's are low and your foot's not in it anyway.1992 CVLX. 5.0 HO/GT40P/T5/3.73/trak-lok with bolt ons. 02 front CVPI setup, rear HPP setup, CVPI shocks around, F250 radiator, e-fans, and the power of 3G. 15.92@89mph, 2.4 60', 4700' elevation (5500' DA) with 3.08 open rear and the old oil chugging 289. RIP.
if you take a stock egr spacer, bore it, and then pack the cavity where the cooler lines went with jb weld, then file it flat it might do the job to seal things up in an acceptable manner. Or maybe it won't. Iunno.
I think the way the Lightning stuff sits from the factory, the throttle cables bolt up to the Mustang-type ears. The Panther-compatible openings are used for smog control solenoids or something.
Other options do involve a Mustang spacer and longer cables from a Fox body car or something, and simply loop the cables around from the front. Doesn't look as good, but sometimes go is more important than show.86 Lincoln Town Car (Galactica).
OK, fast approaching the point where I really need to take care of this, Friday most likely
Because I can't afford ($60+$18 gasoline...) and even more importantly can't wait a week on the machinist (+90 minutes driving/meeting, +1.5weeks waiting)
I'll go ahead and make a bracket to add to the HO intake. And hey, if I do end up getting an explorer intake, I can bore out the HO one, which i can't do to the stock lowpo
Do you know what the tolerances are for the 3 cables that attach to the bracket that bolts to the back of the egr spacer? I.e., if I'm say 1/8" off with my holes, I won't trigger carmaggedon?
Secondly: I've got two options with the backwards bracket. The spring-loaded lever that is peened to the pin that operates the throttle plate inside the throttle body: I can
a) leave the levers on and drill two new holes in the HO throttle body's lever, one for the bushing, one for the little post, and then cut off (from the back) and move the post over. This leaves the joint holding the leaver to the throttle plate virgin, but means trying to accurately place new holes...
b) grind off the peened-over retaining metal and swap my lowpo lever onto the HO intake.
b) is more elegant, what i want to know: is the pin that goes through the throttle plate and which is stuck to the lever also mild steel, such that a 3-second sputter of the mig welder will tack the lowpo lever onto the HO intake nicely and reliably?
Or is it something hardened and slightly exotic, and a mild steel tack weld might fail, leaving the lever lying on the valve covers and the throttle plate flopping free?
thanks for the advice!
Originally posted by BerniniCaCO3 View Postb) is more elegant, what i want to know: is the pin that goes through the throttle plate and which is stuck to the lever also mild steel, such that a 3-second sputter of the mig welder will tack the lowpo lever onto the HO intake nicely and reliably?
If you have access to a drill press, here's what I suggest you do. Remove the stock lever, and remove the HO lever. Do that, by grinding the bottom flat. With a small hammer, work off the lever. Be careful with the LOPO one since that's the one you're using. Get a small bolt a washer big enough to cover the rod and whatnot, a drill bit, and a tap to go along with it. I think I used an M8 bolt. I used red locktite on the bolt to make sure that it's not coming out.
Originally posted by 86VickyLX View PostYou can do that. But be careful, since you're welding around aluminum and plastic bushings, and getting it even a little too hot, and you've melted the bushings and screwed yourself.
I had Lincolnmania do mine. Excellent work and not once had I had a problem with it installed. He tacked it on there for me.~David~
no no no-- I read about the loctite! But for example, you can clamp down on your wheel bearings with a lot of force (not good of course), and they'll still spin. There's no geometric grip, if you will, just the friction between the underside of the screw head and the lever, loctite or no loctite, which was why I was concerned.
But if it hasn't given any issues, and hasn't turned, maybe I'll do the set screw
Or tack weld it...
still haven't decided
Or a set screw, and then a 1second tack weld to stick the screw head to the lever to be sure.
Originally posted by BerniniCaCO3 View Postno no no-- I read about the loctite! But for example, you can clamp down on your wheel bearings with a lot of force (not good of course), and they'll still spin. There's no geometric grip, if you will, just the friction between the underside of the screw head and the lever, loctite or no loctite, which was why I was concerned.
Or tack weld it...
