This is for the white coupe.
302, roller HO cam.
I was looking to drop in my distributor tonight, and noticed that the gear had some wear on it. Hmmm.
I know the application I need is an '85 Mustang GT with the 302, and 4 bbl. However, according to Rock Auto, these existed with and without the steel gear, which is required for the roller cam.
So... judging by the wear on my gear, its an iron piece. I had another distributor that came with the car, and the gear looks much better. But that doesn't mean its steel...
Is there a way to tell steel vs iron, visually?
If not, I am not really comfortable buying another one of these '85 distributors, just to find out it also has an iron gear.
A steel gear from MSD is $70, which is damn expensive for what it is. Mallory has one listed for $35, but I have to wonder why it is so much cheaper than the Comp and MSD offerings. Is it really steel? Further more, install it is not simply plug and play. You have to check a few dimensions, etc. A real pain in the balls.
This kind of shit pisses me off.
Should I just buy an MSD Billet with the steel gear, and be done with it? I like how simple it is to adjust the advance curve; that tunability, and parts availability would probably add another useful dimension to my tuning.
Thoughts on this? Is there a way to tell steel vs iron? Should I just buy the MSD unit?
302, roller HO cam.
