The other thread fulfilled its purpose and evolved into a general thread. Since most modified cars are smogged and are simple HO conversions, let's talk about the limits of mods for passing smog. What will a SD ECM handle for heads and intake before you have to add a chip? Has anyone passed with an HO cam and Explorer intake with heads? What about the Explorer/F150 cam with the same?
Performance Limits with Smog
Originally posted by Mercracer View PostThe other thread fulfilled its purpose and evolved into a general thread. Since most modified cars are smogged and are simple HO conversions, let's talk about the limits of mods for passing smog. What will a SD ECM handle for heads and intake before you have to add a chip? Has anyone passed with an HO cam and Explorer intake with heads? What about the Explorer/F150 cam with the same?
When I was in school and had the D9S (Mark VII Speed Density) in with the explorer (cam, heads and intake) engine, I had low HC, low CO, however since it ran lean, I had high O2, so NOx was a problem. However, I haven't figured out the reason why the computer didn't enrichen the mixture. I'm thinking because of it being bored out, even just .020" was enough that the computer was out of it's operating parameters and that's why it would run lean. The explorer intake manifolds, explorer cam and freer flowing heads didn't help the situation either.
with ported E7 heads and an Explorer intake with an Explorer cam on a .020 over motor, the SD ECM ran way too lean as verified on the dyno. I think it was around 18:1 at points, and at its richest, it got around 14:1. It also pinged terribly on regular fuel with stock timing. The mass air ECM seems to have mostly fixed that, though on rare occasion it does ping a bit. At some point, I'd like to run it on the dyno again to see how close it is to being correct. I've never had problems passing emissions, but here in NJ its an idle and a fast idle test. If you fail that, something is very wrong.86 Lincoln Town Car (Galactica).
Originally posted by mrltd View PostSince my setup does not have a stock cam, I cannot comment.
However, I'm sure there are a ton of threads on this topic on corral in the archives.
Originally posted by gadget73 View Postwith ported E7 heads and an Explorer intake with an Explorer cam on a .020 over motor, the SD ECM ran way too lean as verified on the dyno. I think it was around 18:1 at points, and at its richest, it got around 14:1. It also pinged terribly on regular fuel with stock timing. The mass air ECM seems to have mostly fixed that, though on rare occasion it does ping a bit. At some point, I'd like to run it on the dyno again to see how close it is to being correct. I've never had problems passing emissions, but here in NJ its an idle and a fast idle test. If you fail that, something is very wrong.
Unfortunately jayh no longer posts here.
He had done some serious SD builds.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
Not at all.
Some people here just thought he was. Its discouraging that most of our tech resources get run off...**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
He's just another guy badgered into submission by that guy who left but didn't.
He seems nice enough on sbftech.com
on my towny
ho pistons with stock bore, ho cam, thumper ported e7's, 1.7 roller rockers, ported lower, ported upper, 65mm tb with 63mm egr spacer holley adjustable fuel pressure regulator, 2.25" exhaust........runs like a raped ape with speed density.......when i had it on the dyno in 04 the air fuel ratio was right too
iI am still in the testing stages, however my goal is to see just how far I can take the stock SD system, mods will be added periodically as i get the money, very poss in the near future i will drop some modded 289 heads on, but that is only contingent on wethere or not they are in rebuildable condition.89 townie, mild exhuast up grades, soon to have loud ass stereo....
How about a whole oil burning 289 that runs like a champ?1992 CVLX. 5.0 HO/GT40P/T5/3.73/trak-lok with bolt ons. 02 front CVPI setup, rear HPP setup, CVPI shocks around, F250 radiator, e-fans, and the power of 3G. 15.92@89mph, 2.4 60', 4700' elevation (5500' DA) with 3.08 open rear and the old oil chugging 289. RIP.
