From what I'm understanding, if you were looking for an engine that could make some decent power, but also a light engine, a 302 would be the way to go.
Engine Swaps
There is less than 100lbs difference between a 302 and 351W engine. It only takes 10HP to overcome 100lbs. Unless you are going to stroke a 302 to 347 (or something in-between), a 351 is going to have a natural advantage just because of the added stroke with the same bore. Where engine compartment space is at a premium, a physically smaller block makes some sense. Since most people already have a 302 if we are discussing the CV/GM platform, it is cheaper and easier to just bolt parts on the 302 platform for modest power gains. If you are rebuilding an engine and are upgrading parts, a 351W is an upgrade which can make some sense. If your long term goals are to make a pile of power, a 351W block is inherently stronger than a 302 block and you have the ability to get over 75 more cubes out of it. With a 302 you are absolutely maxed out at less cubes than a 351 starts with.Last edited by Mercracer; 06-18-2011, 06:44 AM.
Originally posted by 86VickyLX View PostFrom what I'm understanding, if you were looking for an engine that could make some decent power, but also a light engine, a 302 would be the way to go.
yea as long as you put it in a light car..Give a man a fish and he will be fed for a day. Teach a man to fish and he will promptly forget that he once did not know, and proceed to call anyone who asks, a n00b and flame them on the boards for being stupid.
351's are fuel pigs tho........not quite as bad as the dodge 360 but still........with fuel being close to 4 bucks a gallon, performance can take a back seat
I was able to pull down 24mpg at 60+ with the 351 I had in my old '88 thunderbird. Around town it was closer to 13mpg...and that was with 3.73's. I'm concerned that it won't be close to that when I drop it in the CV though...more weight and the aerodynamics of a small house. Although the 'bird was 3835lbs with me in it...I don't think my tudor could weigh too much more than a couple hundred pounds more than that. Once you go 351, you can never go back.'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
My two door was on the scale at 3520 lbs. I think you might have had the heaviest fox t-bird ever. As far as gas mileage I'm lucky to hit 9-10 mpg on 93 ethanol free.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
Since the CV isn't my toy car, I'm actually happy with the power that the 289 puts out. That doesn't change the fact that the 302 w/GT40Ps is still going in which = more power, but compared to a 5300lb truck my 3900# CV is pretty snappy.1992 CVLX. 5.0 HO/GT40P/T5/3.73/trak-lok with bolt ons. 02 front CVPI setup, rear HPP setup, CVPI shocks around, F250 radiator, e-fans, and the power of 3G. 15.92@89mph, 2.4 60', 4700' elevation (5500' DA) with 3.08 open rear and the old oil chugging 289. RIP.
Originally posted by Pesty351 View PostMy two door was on the scale at 3520 lbs. I think you might have had the heaviest fox t-bird ever. As far as gas mileage I'm lucky to hit 9-10 mpg on 93 ethanol free.'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
The fox chassis cars, particularly the bigger ones, are not as light as people might think. They are smaller than a Panther, but they have a lot of metal in them. Get a loaded one, and they're really porky. A Lincoln Mark VII weighs as much or more than a Vic does, depending on years.86 Lincoln Town Car (Galactica).
