Well ive been looking for awhile. But I want to get about a 7qt rear sump system but....ive had no luck
Rear sump only setup for panther 5.0
1985 Mercury Grand Marquis ls-302 CFI
Carb swap planned .
c90 heads
475 lift cam
Weind stealth intake(looking for reasonable air gap or manifold for 2bblsidedraft)
Built aod(want c6 tryin to fin vac mod model)
331 stroker kit
Work in progressTags: None
look for Fox Mustang parts. Same oil pans. I think you're limited to a dual sump though.86 Lincoln Town Car (Galactica).
Originally posted by turbo2256b View PostFront sump is to clear the oil pump in a dual sump Ford SB. I run a Canton Fox road race pan. Onl issue was were the rear sump drain plug is. Works with out mods but cutting a hole in the crossmember were the plug is helps or welding a bung and putting the plug on the side helps.
