got a chance to get a 2001 5.0 out of an explorer for $475.00 complete from top to bottom. what would need to done to put this in the wagon and what else would i need to make it work??????
explorer 5.0
explorer 5.0
'88' MGM wagon (mine and my sons toy)
"60" chrysler New Yorker (my project)
"78" Chevy 1 Ton P/U (yard horse)
"01" Ford Explorer (wifes DD)
"93" Chevy Suburban (my DD)Tags: None
take all the accessories off your lopo and put them on the expo motor and either a SD ecu with the right firing order (cant remember the numbers right now) or and a9p or and a9l mustang mass air ecu and do a mass air conversion. ummmm I think you need to put a double sump oil pan of the lopo on the expo motor, possible flip the intake and do the throttle body flip. Thats about all I can think of right now.
'90 LX 5.0 mustang
Big plans
need the lopo timing cover too. not sure about the oil pan. DX3, D9S are two ecus that come to mindsigpic
01 has external egr.......better off with a 96 engine
ok so i should hold out for a "96" than???? any others or just a "96"???'88' MGM wagon (mine and my sons toy)
Ok so you all have tossed out 6 diff. Ecu's at me and I am confused!!! What one should I look for, dose it make a diff,should I do mass air or speed density, what's easier/better and what is involved in the better one??? Or is it all just preference ????'88' MGM wagon (mine and my sons toy)
Originally posted by grandwagon View PostOk so you all have tossed out 6 diff. Ecu's at me and I am confused!!! What one should I look for, dose it make a diff,should I do mass air or speed density, what's easier/better and what is involved in the better one??? Or is it all just preference ????89 townie, mild exhuast up grades, soon to have loud ass stereo....
Originally posted by grandwagon View Postok so i should hold out for a "96" than???? any others or just a "96"???
Speed density should work with the P head explorer motor. Mine only gave issues due to a wiring fubar I did 2 years ago when I put the engine in.
You need your fuel rail, distributor, sensors and such. If you have an early 5.0 sploder, you can use your TPS on the explorer throttle body. That's 96-98. iirc. The later ones you will need to wire in an explorer TPS to your harness. This is also true for the fuel injectors. The later ones have a different plug.
ok i think i got it but why would i need to change the dizzy????'88' MGM wagon (mine and my sons toy)
it's got them space aged coil "PACKS"......fucking wizardry if you ask me.sigpic
96 cause it has gt40 heads and the upper intake with internal egr
some early 97's with gt40p's have internal egr
you can use the later engines but the intake manifolds wont work unless you do an egr delete or weld a egr tube to the right header
