I think I may have asked some of these questions before, but I wasn't serious about anything at the time and I've forgotten what advice I may have received.
On Tuesday the 24th I'm yanking my engine again. Why? 'Cause my oil pan is leaking from a crack, AND, my rightside header gasket is blown and my header bolts are mostly stripped out. Either one I might just do with the engine in the car, but with both of them, I might avoid some grey hairs by just biting the bullet and pulling the engine.
by the way, when I reado that header, what's the proper length header bolt, and should I use a lockwasher?
SO, while the engine is all out again, may be the best time if there are any last things I want to do to this engine.
What I have now is:
Mark vii speed density computer
stock HO block w/ forged connecting rods, flattish topped pistons
stock HO intakes
stock HO throttle body; modified to accept panther linkage
stock airbox
explorer camshaft
explorer gt40 heads
mustang shorty headers, h pipe, impala tailpipes for dual exhaust
timing is correct for stock spec. Plugs and wires are pretty new, and quality (iridium and silicone respectively), and and rotor are fresh, so those basics have always been good. Dunno what my fuel pressure is. Seems to be running rich usually, just on the basis of fuel economy/ slight fuel smell whenever I do an oil change.
I have lots of power 2500-3500rpm (in my highly inexpert and inexperienced opinion), but it seems to fall on its face and just not deliver past 4000rpm if I stab the go pedal.
Would a proper HO camshaft now be appropriate, with my 3.55 rear gears, now that I see 2000rpm+ consistently? (used to be I hung out at 1500rpm all the time).
Local guy has a ground billet camshaft for $150, stock HO specced, might actually be more precise than factory oem? (it's from CI cams?)
Also found these heads for sale locally, dunno if they're better than the gt40 heads I've got, or $300 better any way: http://baltimore.craigslist.org/pts/3086357317.html I'd have to buy rockers for them.
Finally, wondering about a proper gt40 intake rather than the HO.
I don't want to go too far, however, and seriously trip up my speed density system. I don't know at what point you need larger injectors (and I guess that would require a modded ecm to accommodate?). I don't know, if I put on an explorer throttle body, how to tell the ecm that it's now got a larger throttle body and to calculate for more airflow. I don't know if I put 1.7 roller rockers and a gt40 intake and tb and those windsor jr heads, if I'd lose the low end I've got? I don't want to build an engine that now has power at 4000-5000rpm, but none at 2000.
Final question on the side. If I put in an HO camshaft, I might as well toss the cheap ass chinese CAT lifters I bought a year ago. They're working fine now as far as I can see, but even out of the box you could tell there was more slop than oem lifters. What brands do you recommend for a quality build?
What I have now is:
stock HO intakes
stock airbox
explorer camshaft
explorer gt40 heads
