I know this has been asked at least once before but hell if I can find the thread, what are the best after market intake's that can be reversed to face the drivers side? The vast majority of them have offset bolts in the center (the TrickFlow ones for example), and can't be rotated properly. After much research, it seems the best option is the Professional Products Power Plus Typhoon Intake, which is just a cheap clone of the Edelbrock Victor. I think turbo had a Professional Products on his car at one point. Anyone else have any info to share/ideas?
Aftermarket reversible EFI intake manifolds?
1987 Colony Park - 03+ frame swap, blown Gen II Coyote, 6R80, ridetechs, stainless works, absolute money pit. WIPTags: None
Here is a trick flow. What is not proper aside from the foolish text?
Note the offset bolt holes in the center. Unless they drilled and taped new holes, there is no way the center bolts are in there.
You can even see how they are offset on the top.
Last edited by pantera77; 03-13-2013, 09:39 PM.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Dont the stock upper and lower intakes have offset center bolts too? Im very confused now lol.
Originally posted by marquisman View PostDont the stock upper and lower intakes have offset center bolts too? Im very confused now lol.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Yea, the writing would drive me nuts too. But, to each his own. Im sure you will find a solution
OK, I think I just went retarded (or have had way to much Blue so far tonight)
Anyways, let's look at what definitely won't work.
Holley 5.0L EFI Intake Manifolds 300-72S
Edelbrock Performer 5.0 EFI Truck Intake Manifolds 3841
Edelbrock Pro-Flo XT EFI Intake Manifolds 7128
This is the one I keep thinking of, but note it has the vacuum lines ports in the back, (which would now be the front for us)
that vacuum port up front might be kinda nice actually.
i know the typhoon works, installed one on project79.
Originally posted by Lincolnmania View Posti know the typhoon works, installed one on project79.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
If the Trick Flow intake center bolts don't line up, then how did the guy in the pic (I forgot the username here) get it to work on the Country Squire? When I get home today I'll play around with the Trick Flow intake, I thought it lined up though.
Originally posted by packman View PostIf the Trick Flow intake center bolts don't line up, then how did the guy in the pic (I forgot the username here) get it to work on the Country Squire? When I get home today I'll play around with the Trick Flow intake, I thought it lined up though.
http://www.grandmarq.net/vb/showthre...cFlow-kit-swap
http://www.grandmarq.net/vb/member.php?3773-vabeachsandVic
Originally posted by VicCrownVic View Post
Yes, I know, we've been discussing this.
I know someone on here years ago said the Trick Flow intakes don't fit for one reason or another. Maybe it was an older version of the intake, or maybe it was Pirate messing with us, who knows. Brent has proved the intake fits (although the backwards text would drive me insane).
I'm interested in the Typhoon Intake right now, but it seems to get pretty much mixed reviews. It's the cheapest aftermarket intake in price and quality it seems.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
What kind of mixed reviews does it get?
