That's a lot money for a boat anchor.
need pros and cons
+1 boat anchor.
The motor mounts and trans bellhouse also will not mate up. If you're going to the trouble of fitting a 351M, go 400 and put the Cleveland parts on it. Effectively its the same engine, but you at least get another 50 cubes out of a 400. They're also similarly "challenged" in the oiling and performance department. Stock I think the 351M made about what the stock lopo EFI motor made.86 Lincoln Town Car (Galactica).
I'd tend to agree, unless you throw some good heads at the Midland motors. For that cheap it may balance the cost of a set of heads. Always wanted to do a Cleveland in my early Fox coupe but it was never meant to be. Lost my job, had to move and sell the car for nothing just about. First year California Highway Patrol car too, breaks my heart...
429/460 engine family would be the way to go if you want big block. Much better parts support. Smallblock tends to have the Windsor as the winner, and for the same reason. A Cleveland kicks ass in potential, but they haven't made them in a really long time, and the parts just aren't cheap. 302's and 351's are plentiful. No, they're not particularly unique, but if the goal is reliability and not spending a fortune it makes good sense to use something proven. Hell, much as I will probably come to regret saying this, I'd probably consider a late model 4.6 swap before using a 351M/400, FE, or any of the other oldie motors in one of these cars. at some point being able to get parts you can afford takes priority over being the only one in town. Find a wrecked Navigator and snatch the 4 cam 5.4 out of it if you want something a little different.
I saw a restomod C3 'Vette on Jay Leno's Garage last night. Supercharged LS6, something like 425 hp with a stock motor and a bolt-on blower, mated to a stock 6 speed stick. I talk shit on the engine crossbreeds as much as anyone, but I have to admit a wagon with that driveline would be bad-ass enough for me to shut up about it.Last edited by gadget73; 09-01-2015, 05:49 PM.86 Lincoln Town Car (Galactica).
You don't need anything fancy if all you want to do is go fast for cheap, the JY 4.8/5.3 + chinese turbo is an impossible combo to beat.
Lighter, cheaper, and easier then using an ancient 385 series.
With that said, if your goal is 13's that's easily attainable with a sbf, but the engine is that last place I'd start. These car's are complete garbage in stock form at anything other then being a highway cruiser. Suspension, brakes and chassis will need a major overhaul if you want to reliably run 12/13's.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
well the engine is the first place i have to start because the one in the car is no good, has a bad rod knock'88' MGM wagon (mine and my sons toy)
"60" chrysler New Yorker (my project)
"78" Chevy 1 Ton P/U (yard horse)
"01" Ford Explorer (wifes DD)
"93" Chevy Suburban (my DD)
