'07 Mustang GT Rims
    Originally posted by mrltd
    The problem is the front, it'll more than likely hit the upper control arm. If they will even clear the hubs.
    The other wheels are the same, the finish is slightly different. Full polished vs. a polished/as cast.
    You would need at least a 1.25" spacer. Nate has marauder wheels on his 85, and those have the same backspacing/offset as the mustang wheels. (IIRC)
    They look like they have a dish on the spokes?
    There is a fair bit of room to the control arm, and with a 17", wouldn't the wheel be ABOVE the control arm? I guess its mock-up time and see
      OK, now with a spacer as small as 1.25, would I just use long (IHRA/NHRA ) studs and bolt THROUGH the spacer, or are they bolt-on as well?
        On anything more than 1/2" I'd go with the adapter. I'm running 1" adapters on mine to get the bullitts on there.
          they are bolt ons, its called a wheel adapter. Get one with the same bolt pattern 4.5in- 4.5in. They sell ones that will go from 4.5-4 3/4 and ect...
            And these things are safe?
              I've beat the crap out of my car with them on, 1200 mile trips, autocross.....I still would prefer not running them.
                What brand are you running?
                  hubcentric ones would be ideal because they have a lip and will fit directly on the hub with no play. I had no problems at all with the spacers I got of ebay. I drive pretty spirited too.
                    Some ebay ones...I had to replace the studs, they were too short and not 1/2-20. I would have liked to get hubcentric ones, but I didn't see any at the time.
                      SO, like these?
                        yup
