so when I was going to work yesterday. I heard a grinding sound first I thought it was my rear getting real bad. So then the car locked up I looked at the front right side rotor and sure enough the inner side of the right rotor is all grind up. I had to tow the car back to my dealer. When I put it in drive then slightly touch the brake the front locks up.
then when I put it in reverse it frees up. me and scott did the bbs 2 months ago everything is new. so do you think it is the caliper locking up or are the slides froze up? I'm not sure if I remembered to lube the slides it was a long night. thanks mangs
