Tie Rod Adjusting Sleeve
    Anybody know of a solid Tie Rod Adjusting Sleeve ?
    The stock sleeve is kinda cheap and easy to bend. Wouldn't a solid bar that is drilled and taped with jam nuts work better?
    they're all like that as far as I'm aware. All the replacements are just like stock, and every vehicle I've owned has used the split sleeve thing. Yeah they suck, but 20 bucks gets you a new one.
      OK, thanks
        if you can figure out the threads, look through http://www.speedwaymotors.com/sleeve...%7c108=Sleeves
          Looks like I find something to work from them. Thanks
            post it up for others
