So i went to find out all the codes i needed to figure everything out about my car...but the the tag has been previously removed from painting or whatever. so wat not? can it be tracked by the VIN? or find a Build Sheet?
Wat to do about no Tag?
Most of the stuff you can look at and figure out. The axle code, which I assume you are asking about since you posted here can be found on the door sticker and the tag on the rear diff.Builder/Owner of Badass Panther Wagons
run your VIN through
it'll bring up a page with all of your cars data on it. engine, trim level, axle/paint code, etcsigpic
heres mine as an example
