Hi!
Bought a 1990 colony park 2months ago. I'm a college student and this is my first car.
To get it to pass inspection, yesterday (...and into today) I replaced the front shocks.
My god, the top nuts were hard to get to and impossible to remove. I spent literally 5 hrs with the driver side nut, shredding the shaft with a locking wrench before finally running out to the store and resorting to a dremel cutoff wheel, which only barely sufficed. It couldn't, actually, reach the shaft due to angles; but i was able to slice up the nut until it broke free.
So tomorrow I'd like to do the rear shocks, but I confess that I'm terrified. I was told that they're even harder to get to (is that possible?), and if the nuts are as frozen as the front ones were, it seems likely that I'll never get the 20yr old shocks off??
I'm also nervous about the warning that I have to brace some part in the rear before removing the shocks, or the axle will come down? Not sure if I understood the haynes manual correctly.
