'cuz everything's in pieces, duh.
Rebuilt valve body
Originally posted by gadget73There is nothing more permanent than a temporary fix.
Originally posted by slymer View Post*doesn't know much about transmission innards*
why's he need a new one?sigpic
ah... I was wondering if something looked obvious in the picture (other than it being apart).
Originally posted by Pirate View PostI can see why you're needing a new one.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
Originally posted by Lord Iffy View PostI have cleaned everything, assembled it together (the same way it was before...) but now I have troubles with high main pressure - no upshift from 1st gear, basically I believe that first I shall try valve body (two springs were broken I have replaced them, but maybe there is problem), than governor and then new transmission2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
Originally posted by 88grandmarq View PostPirate is commenting on the dirty rag/blanket all the valve body pieces are dis-assembled on. ANY amount of fine grit, lint or dirt in the bores and on the parts will cause them to hang and/stick.
Unfortunately I believe I have already tried whether the nut is over tightened, that is not the problem Even with the shift linkage and TV cable unconnected and with the the lever all the way back the TV pressure as well as the main line pressure was too high (now I do not remember how high, but cca three times more it should be)sigpic
