I spent the last 3 weeks rebuilding a transmission, an AOD for my car. It came out of a 1980s mustang; guy on craigslist was swapping to a manual.
I went to install it tonight, and, guess what-- driveshaft doesn't fit.
I do not know WHAT chain of events lead to this (ending up in a mustang), but obviously, this is a lincoln or truck AOD. The tailshaft housing section seems to be about one inch longer, as is the tailshaft itself. I had no reason to have checked, as this came out of a mustang, so it shouldn't have been the longer transmission. But it is. Gotta move on and figure otu what to do next.
I can uninstall the new transmission, tear down both my new and old, and get the right tailshaft. That's a lot of work and wasted effort.
Seems the easiest is to have a shop cut down my driveshaft?
Can you foresee any issues with this?
Should I just have a shop shorten by exactly 1", and rebalance, maybe with new U joints for good measure (I'm pretty sure they're original, though they don't have any discernible problems-yet).
How much might this cost? If it's <$150, excellent, worth it compared to the alternative-- tearing down two transmissions!
And, just to make sure, there's no reason this shouldn't work?
And, if I ask them to trim my stock driveshaft by 1", that will work? Any other measurement you might go on?
For an AOD, is there any other length, other than 1" longer or not, to be wary of? My measuring technique was crude, consisting of a tape measure at an angle; though it does seem to be 1" too long, give or take a quarter of an inch.
