I found a low milage aod from 88 Tbird to put in my 80 ltd. As I understand they are a little shorter than passenger cars aod. How much shorter? Or can a 4dr TC driveshaft made to work?
Extending driveshaft? Cost?
“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -AnonymousTags: None
the drive shaft is shorter... the AOD should be the same except with the high rev governor.
the drive shaft is shorter... the AOD should be the same except with the high rev governor. The TC drive shaft I think is actually the same or longer than an LTD.
only the Lincoln AOD is longer. Ford and Mercury car transmissions are all the same length. Put it in, you'll be fine. The 88 Tbird doesn't have the high rev governer either. Not an HO in the Turd until 1992 I believe.86 Lincoln Town Car (Galactica).
that's handy info.
If its a Lincoln Mark VII transmission from 1988 onward, yes. If its out of an 86-87 Mark VII LSC, yes. If its out of a Towncar, definitely not. Mind you this presumes factory original stuff. My Mark VII has a Ford reman trans, and I'm about 95% sure its got a low rev governer in it. Its not supposed to, but it does WOT shifts about 4300 rpm.86 Lincoln Town Car (Galactica).
Originally posted by BerniniCaCO3 View Postmercracer, do you mind posting a photo?
The tailshaft is just 4 bolts, and as it happens, the driveshaft is already out... so I think i'll take a look-see tomorrow night!Last edited by Mercracer; 03-04-2012, 09:21 PM.
