Transmissin bellhousing to engine bolts difference?
    When did Ford changed trans to engine bolts size? (what year?) I remember reading somewhere that earlier aod used skinnier bolts while later used thicker and longer ones?
    “Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
    The thread holes in the block are the same for all years 302/351W. I will try to look up the bolts from 1980-1990 and see if there was any change in length.
