There are two reasons for this.
One is that in a toasted transmission, the gritty mush that is what remains of the clutches might be all that allows them to hold at all, and once rinsed out, your clutches and bands might slip terribly;
Two is that if there is a buildup of grit, cleaning this out could free chunks of clutch material, that then get caught in the very fine tolerances of the valve body, and other funny stuff happens.
Since you've kept up with your fluid changes, it sounds like, you probably don't have this severe buildup of clutch material. I'd go ahead and do a flush. By "just did one 20,000 miles ago," you mean 20,00 miles and 2 years?
That rule is for folks who never heard of a transmission flush, and now their car is 15 years and 150,000 miles old, and it's starting to have shifting problems, and only now they're considering a flush. At that point their transmission is probably cooked, and they're on borrowed time now matter what course of action. A flush could either buy a little time, or rob them of what time might be left before the transmission goes from problematic to completely unusable. The transmission was already destroyed either way and what is being discussed is bandaid measures. To say old transmissions "like" dirty fluid is a misnomer
