Mercon V In An AOD?
    Mercon V In An AOD?
    Any benefits of this as opposed to the traditional trany recommended fluid? I know there are additional friction modifiers but any real benefit?? Thoughts??
    Supposed to stop shudders. Idk I always change all my cars to mercon v when I get them.
    '90 LX 5.0 mustang
    Big plans
      Any other thoughts????
        Its what Ford recommends now. Its semi-synthetic and supposed to hold up better to heat than the old Mercon/Dexron III.
          Wonder if the "feel" of the trany would be different?? Car has a large trany cooler so temp would probably not be an issue.
            feel is the same as far as I can tell. I'm pretty sure the 88 has V in it. Whatever the shop put in it when they rebuilt it.
              Makes a guy wonder how a Dex3/Merc GM trans would like it?
              1992 CVLX. 5.0 HO/GT40P/T5/3.73/trak-lok with bolt ons. 02 front CVPI setup, rear HPP setup, CVPI shocks around, F250 radiator, e-fans, and the power of 3G. 15.92@89mph, 2.4 60', 4700' elevation (5500' DA) with 3.08 open rear and the old oil chugging 289. RIP.
                you can use mercon V if you want, just be sure to drain the torque converter too.
                i'm still using dextron III in my stuff, mercon5 costs twice as much
                  Great thoughts and thank all of you for taking the time to respond. Something I've been curious about for a while.....
