Hi Folks,
I need to do something with my rear end. Currently it is the original 3.08 upgraded with a posi clutch pack plus repair axel bearings.
What I would like to do is keep with the 3.08 posi, so I do not need to play around with speedo gears.
Plus convert to to disk and change my existing air shocks to air springs.
There is a yard in the bronx with numerous late model rears with the calipers and rotors included. Plus they have TC air springs.
I did some searching here to find some threads I read in the past which had good info but I could not find them.
From what I know, 92 to 97 is an easy swap. What would need to be done to use a late model rear?
What type of controls and compressor are needed to run the air spring suspension? Is the contol system seprate or integrated into the main computer?
Thanks,
Jay
Thanks,
Jay
