Thinking of putting these on my 88 MGM but don't know if they will work
Will These wheels fit
These should fit pretty well: with a -6mm. offset, you'll be at about the same centerline. Unless it's a typo, I'have some concern with a 3.365 inch (!) center bore. That's big! If the wheels don't center snugly on the hub or axle ends, the only thing that keeps the wheel spinning concentrically with the hub/axle would be the taper on the lugnuts. Centering rings are available to choke down the size of the center hole, but they ain't cheap. Has anybody successfully used a wheel that didn't center on the hub/axle?If you're gonna be dumb, you gotta be tough...
Originally posted by GoFordBroke View PostThese should fit pretty well: with a -6mm. offset, you'll be at about the same centerline. Unless it's a typo, I'have some concern with a 3.365 inch (!) center bore. That's big! If the wheels don't center snugly on the hub or axle ends, the only thing that keeps the wheel spinning concentrically with the hub/axle would be the taper on the lugnuts. Centering rings are available to choke down the size of the center hole, but they ain't cheap. Has anybody successfully used a wheel that didn't center on the hub/axle?1989 Grand Marquis LS
The aftermarket '03 Cobra wheels that I originally got for the CV had a smaller center bore. I ended up returning them for that reason. If I can't find decent 2nd gen Lightning wheels for my Ranger, I will probably end up getting the '03 Cobra wheels for the truck.
BTW; does American Racing make anything wider than 15x7? Unless you're not after the big and smalls look.
Wheels center on the hub or the lug nuts. If you have acorn lug nuts they center on them. It doesn't matter about the center.89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
