Hey guys, my car has had the misaligned indicator needle since the day I bought it. It doesn't really bother me, but it would be a nice thing to have fixed. I'm about to head down to a JY in Charlotte that has three box Town Cars (an 87 and two 88s) that look relatively intact. Do you think it would be worth it to pull a new indicator cable from one of the cars there? The last junkyard I went to wanted me to buy the whole dash cluster with the cable, but I don't think this yard really cares. Is it a pain in the ass to remove?
Shift Indicator Cable from JY
2018 Toyota Tacoma TRD Sport | 97k milesTags: None
if yours is actually working, but not in the right place, just take the column shrouds off and zip-tie the bastage in place. You will probably not ever find one intact in a junk yard... and if you do, you will probably break it taking it off. Just make sure the zip tie is UNDER the cable and over the collar. This can and will be a good trick to figure out, but shouldn't take any more than 30 minutes all told to get fixed.
it not really the shift cable its self as much as the indicator wire thingy, usueally when the trans has been replace the collar inevitably gets broke and will move cuasing the indicator to be off a little bit.its on the column .89 townie, mild exhuast up grades, soon to have loud ass stereo....
Go to Ford and see if they have any. I got mine from Ford and they had a few remaining. Junkyard ones would be very rare. And even if you found one now, it would most likely break due to the cold temps and what you need to do to take it off.
