Here is a video of my drivers outter tie rod. Does the up and down motion you see here mean it's bad?
Bad Tie Rod Video. Opinions?
87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
Mods to come: Big Brake/Poly Front Swap, PI Front Swaybar, Addco 650 Rear Swaybar, Boxed Upper Rear Control Arms, 351/Alum Heads, FRPP Valve Covers,Tags: None
I could not really see that.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
it shouldn't do that but the more critical play is side to side. Rock the steering wheel and see if the tie rod moves before it pulls the spindle along with it. I'm betting it does, which means its done.86 Lincoln Town Car (Galactica).
thats scary!
i would start ordering parts and replace everything
The tie rod also has side to side play, but I didnt get it in the video while up on the lift. The mechanic was being a douchegrip. 2 months ago I slammed a crater in the ground caused by a construction company and began to have a knock in the right front. I thought it screwed up the rf shock. After inspection the only thing we could find was the bad tie rod and a junk pitman arm. I have to send that video in to their insurance company and theyre hopefully gonna cover the tie rod.87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
E.S. Bushings, big brake swap, tie rods, sway bar, springs. All happening at the same time within the next couple weeks.87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
That thing is handle nice! Which springs are you going with?2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Hey Pantera. I've got wagon cargo coils from autozone out back, and I will run cut p71 springs up front.87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
When you by tie rods, do you buy just the ends, or the hole kitten kaboddle?
I was going to get four of this
ACDELCO Part # 45A0210 {#88910044}
ROD,STRG LNKG OTR TIE -
and for the U-joint I was going to get this
MOOG/PRECISION Part # 354 Premium
At Transmission; w/3-7/8" O.D. Yoke; w/Towing Option; w/1-1/16" O.D. Bearings
At Rear Axle; w/3-7/8" O.D. Yoke; w/Towing Option; w/1-1/16" O.D. Bearings
(((((But I noticed two sizes for U-joints for the same car. What gives?"To Find yourself, you must first lose yourself"
-1973 Volkswagen Bus Westy
-1986 Honda Magna 700cc
-2011 Subaru Outback
depends on what's bad for the tie rods... typically it's just the end joint.
U joints have two options... the larger is for tow-package cars usually (or police/performance). Most civilian cars have the smaller one. Always best to know which one you need before purchasing by measuring.
Ok, I gotcha, so measure the diameter of the U-joint>"To Find yourself, you must first lose yourself"
here's a page that shows where to measure: http://www.actionmachineinc.com/ujoi...ringguide.aspx
Normally just the ends are bad, but if the sleeve is old, it may not let go easily. I've replaced mine for that reason. Sleeve is typically about 20 bucks, so if you have to replace both ends, it doesn't really make sense to me to fight with the rusty sleeve.86 Lincoln Town Car (Galactica).
I see, interesting. How would you diagnose a bad tie rod?"To Find yourself, you must first lose yourself"
