On Rockauto there are different size u-joints available for my car. On some the O.D. yoke size is 3 1/2" while for others it is 3 7/8". Which size will work on my car? If it's important, my car does not have the towing package.
U-Joint part # for '89 Town Car
2018 Toyota Tacoma TRD Sport | 97k milesTags: None
best bet... crawl under there and measure it.
When I go under the car, what exactly am I measuring? I don't know where the part is.
the u-joints are located at each end of the drive shaft (the cross looking parts). You're measuring the bearing cap side (mounting hole in the drive shaft) and distance from cap to cap (outside).
U-Joint Identifier: Use this simple form to find your U-Joint series from your U-Joint dimensions. You will need to know your cap diameter and u-joint width. OR you can find your u-joint dimension if you know your series.
check that page... it has diagrams and stuff.
