Tires
    Tires
    What would be the closest size to a 205-75-15 tire?
    215-75-15, or a 215-70-15?
    Thanks for the education
    215-70-15 will be closer. middle number is aspect ratio, so the height of the sidewall is that percentage of the width.
    .75*205 = 153.75 mm wall height
    .70*215 = 150.5 mm wall height
    .75*215 = 161.25 mm wall height
      Get 225/70/15's if you want a factory size tire.
        My '86 Tudor came with 205-75-15.
          Yes, but 225/70/15 was a standard size for police, ect.... A bit wider and just a touch taller. Good choice if your replacing tires but staying with the stock rims.
            Thanks, I did not realize that!
              Hmm, what is the difference in the width of the tread?.....
                the first number indicates the tread width in millimeters. Your's are 205mm, 225/70R15's would be 225mm across with a 70 aspect ratio and 15" rim size
                X2 on getting the 225's
                -Phil
                  This! Ran this size on stock rims for years. Have a set on the wagon.
                    tire size calculator shows tire height comparison: http://www.miata.net/garage/tirecalc.html
