Why? It shifts fine and the car starts right up just fine after it stalls out, never had this happen till about a few days ago when I drove it around the block to "stretch its legs" from sitting 2 weeks. as soon as the car is moving it shifts normally and when its idiling its also fine..its only when I go to shift into D or R. shifting back into park or neutral is fine.
Car wants to(sometimes dies) when I shift into D or R
2011 Ford Ranger Sport 4.0 2wd - Magnaflow Axleback exhaust, K&N 63 Series CAI, DiabloSport 87 Octane tune, LEDs, 3000K LED projector fogs, 5000K Mini H1 projectors - Daily
1967 Ford Galaxie 500 Sedan "C-Code" - 289 2bbl/Cruise-O-Matic - Money pit/projectTags: None
check the throttle body for carbon buildup behind the flapper. If it's all black behind that... hose it out with carb/throttle body cleaner according to the directions on the can and nail the holes in the side that you can see as well (should be to the right while staring in the throttle body). That is usually the issue if it's not a dead/disconnected/iffy contact IAC.
Originally posted by sly View Postcheck the throttle body for carbon buildup behind the flapper. If it's all black behind that... hose it out with carb/throttle body cleaner according to the directions on the can and nail the holes in the side that you can see as well (should be to the right while staring in the throttle body). That is usually the issue if it's not a dead/disconnected/iffy contact IAC.
Throttlebody is clean, Where is the IAC on these? I've never owned a box panther so I don't know a whole lot about where everything is on these cars yetLast edited by 89TownCar; 06-17-2014, 03:58 PM.
IAC is on the back side of the throttle body. It's a tiny metal barrel held in with two nuts and with an electrical connector at the bottom.
hose out the ports from inside the throttle body first. that may be all you need to do. I do this with very short squirts from a carb/throttle body cleaner can with the engine running (since no mass air sensor required to run it)... this way it pulls the cleaner through the ports and cleans the plunger too.
