I have been going through tie rod ends,about four in the last two years. I've had it aligned twice.
In the spirit of a gmn member that is the only job I farmed out. (the alignment)
Upon close inspection it appears that the lower ball joint drivers side is moving slightly in the a arm.
I feel I know the answer to this question but will an a arm off an 86 tc fit on my 89 Cv?
Headed to the yard if answer is yes.
