Flush it all out, and go with Mercon V
Dextron 2 or p/s fluid?
Originally posted by PICKUP6772 View PostFlush it all out, and go with Mercon V
With this one, its far more about viscosity than additives. The friction modifiers and all that do absolutely squat for you in a power steering application. All the pump cares about is the right thickness of fluid so the pressure ends up about right. When the pump wears a bit, the thicker Type F works out better to quiet it down. Same principal of running heavier oil in a tired motor so it makes oil pressure.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostWith this one, its far more about viscosity than additives. The friction modifiers and all that do absolutely squat for you in a power steering application. All the pump cares about is the right thickness of fluid so the pressure ends up about right. When the pump wears a bit, the thicker Type F works out better to quiet it down. Same principal of running heavier oil in a tired motor so it makes oil pressure.
If you have any left over, mix it 50/50 with acetone to make a good penetrating oil on the cheap.86 Lincoln Town Car (Galactica).
by a wide margin. I found the article somewhere but basically a number of different lubes were tested on a rusted fastner and the one that required the least amount of torque to break loose was the acetone/ATF mix. WD40 is pretty shit as a penetrating lube. Considering thats not what it was designed to do, its to be expected.
hmm... I'll have to try that.
