As I started to add power parts to a lo po , the car developed wheel hop while doing burnouts. It hop twice to tree times until 45 mph indicated and then it regains traction. So what is the solution to stop wheel hopping?
Wheel hop and what to do about it?
“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -AnonymousTags: None
My first impression was that maybe you need more weight in the back, but the following link indicates it's probably a suspension bushing issue:
If your car has high mileage and has never had the bushings replaced, now might be the time.
peg legging? or do you have a trac loc? I don't see a lopo wheel hopping up to 45 with both tires spinning.....~David~
are your rear shocks and springs in decent shape? Tired shocks will let the wheel tend to hop more than ones that are working right. Second the thought of a traction lock and/or replacement bushings too if appropriate.86 Lincoln Town Car (Galactica).
Shocks would be my first step
Stop doing massive peg leggers.
Problem solved.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
No traction lock on this one. 3.08 gears. Mods are: 3g alt, Ho throttle body with bored out egr spacer and upper plenum,bypassed water thru egr spacer, nothing after cats-side exhaust, pcv converted to road draft (no pcv screen),no ac or air pump,police speedo. THe same mods on other car resulted in 160rwhp 280rwtq. I'm thinking about putting wagon springs in it with new shocks.Last edited by 90ltd; 10-05-2014, 02:02 PM.“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
Originally posted by turbo2256b View PostWhat are you doing reving it up in neutral and dropping it into 1st. MYSELF WITH ALL MY different ENGINE BUILDS SEVEral BOXES have never experanced wheel hopp nor have anyone else reported wheel hop“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
Originally posted by turbo2256b View PostAre you running space saver spare tires.“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
Back to basics, shocks, springs, bushings, springs in that order if not at once. Trac-loc is generally a net positve except for low powered cars with no winter and or mud to worry about.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
use the brake
could just not do burnouts.
