Cargo Coils?
    Originally posted by Grand_Marquis_GT
    I know they are variable rate...
    nevermind then. I will probably get the 300 in/lbs chevy springs then.
      Isn't that a little high for a drag car?
      Nick
      88 Colony Park LS
        Silly! His car isn't a drag car! It's more of a road race car!
          Yup. If it was a drag car i would not have shortened police springs and a wagon sway bar in the front with heavy shocks and police springs rear
            You can add me to list panthers with the wagon springs. I just need to get mine installed.
              I thought with the huge rear tires and stockers up front it was a drag car...yea I'm out of it today, sry.
              Nick
              88 Colony Park LS
                It is going to get a good size tire up front, the rears were the most important because any thing above about 1/4 throttle and the tires would just spin.
                  :cry: Unfortunally I couldn't get the TRW cargo coils I check here in P.R. at Advance Auto and they can getém for me but we are talking that I have to invest in the price of the coils,insulators and shipping costs $ 300.00 dollars !BUT! it doesn't mean that in a future I can buy them. :smirk:
                  ATT, SNIPER 308. " I THINK THEY ARE GONE " Tomb Raider.
                  MERC75-INTERCEPTOR, BORN IN 2003,DIED IN SEP/21/2010 AT 9:55AM AT THE SORT AHE OF 8 YEARS PROTECTING HIS OWNER TO DIE
                    Sniper, that's a complete BS they've told you - these springs currently sell for about $70 and shipping will be even less than that. I used USPS's calculator to see how much would be for me to ship you the springs, and guess what - 32lbs package to Puerto Rico via Express Mail (overnight) is only $75! That makes a total of $175, which is significantly less than the $300 Advance quoted you... And if you can find someone from Florida to buy and ship you the springs via Priprity Mail (3 business days) it's gonna be less than $45.
                    I just checked PartsAmerica.com, they have the CC819s for $66.96, go here and try to see how much the delivery will be to your place.
                      Thank you IVAN D for that info I will check in that link tonight.
                      ATT, SNIPER 308. MIGHTY LORD OF THE UNDERGROUND :andy:
                        Which front springs where you using at the time of this photo?
                        Alex.
                        Originally posted by Grand_Marquis_GT View Post
                        AOD clearly bought the WRONG FUCKING COILS, and is a fucktwit.
                        I told you, use the same coils I run...
                        TRW # CC819, they are about 65 bucks...
                        These are some of the heaviest duty rears I have seen.
                        Plus, I run them. It gives my car a NATURAL rake. That ain't airshocks, folks!!
                          Those are stockers, with KYB GR-2 shocks. 1984 spec stuff.
                            Does Advance still carry the rear wagon coils?
                            "No other man-made device since the shields and lances of the ancient knights fulfills a man's ego like an automobile." -Sir William
                            2011 Lincoln Town Car Signature Limited- Black on black, ADTR sway bars, 19" Mustang GT rims, Heinous rear control arms, dual exhaust with Flowmaster 10 series mufflers. MHS Stage 2 heads/cams, 80mm MAF, 75mm BBK throttle body, Accufab plenum, Stainless Works long tube headers, Ford Racing 24# injectors. ADTR T56 swap with Hurst shifter. 264HP/298TQ at the rear wheels.
                              :raises eyebrow: really? So much for making my decision easier. =-) I don't even have that front end height with the moog HD sedan front springs. I still had a rake with those and the 817 coils (even moreso now that they are worn).
                              I'm open to suggestions here folks,
                              I've got 8652 front springs and 817 variable rate rears. I found them a bit soft even when new.
                              Requirements:
                              -Firmer than the moogs listed above
                              -AND the same, or more ride height. Absolutely No lowering. I need snow drift clearance, and easy ingress and egress for two people who can't bend very well. Straight rate rear springs are acceptable.
                              I was originally thinking of utilizing P71 front springs ("N") and moog (Wagon variable rate) 819 rears or wagon straight rates. But have been thinking about pairing the fronts with fixed rate later model P71 rear springs (probably whatever incarnation ford has of the "E" spring) for a better balance. Anyone run this combo? Thoughts on it? Car still level or raked? (I want to avoid a front high stance)
                              Alex.
                                NAPA has some really heavy duty cargo coils, I forget the specs, but I think they top the 819's (don't quote me on that) find them here- http://www.napaautoparts.com/MasterP...le+Rate+-+Rear
                                I'm getting these on Friday, if you don't get to them first.
