Got new 2002 upper ball joint and cam adjust slots are different from the 1994 ball joint can I still use the 02 ones
Upper ball joint
Yes. It just changes which adjuster changes camber/caster. Use the appropriate ball joint for the knuckle. The control arm will work fine.
Yes. The older ones are LH and RH, the later ones are the same both sides. Both will fit either spindle, just make sure you get it aligned. I'm using 94 arms and ball joints on mine with a 2000 spindle.86 Lincoln Town Car (Galactica).
