Weeping big brake master cylinder resrevoir cap.
    I have a 98 to 02 master cylinder on my big brake swapped 1987 crown vic.
    My master cylinder cap is leaking very little fluid every time I drive it.
    I have already replaced the gasket with a new "help" item and it is doing the same thing. No better and no worse.
    The master cylinder reservoir is not over filled and only slightly weeps down the side and sits on the lip of the reservoir.
    What gives?
    I am tempted to cut a thin piece of rubber and sip that behind the main gasket in the cap to get more seal out of things?
    Suggestions? Thoughts?
    Wonder if the cap itself is warped/damaged? If the gasket is good (?) then it must be the cap or reservoir surface itself. Can you run a metal ruler over the reservoir surface to check for uneven surface? This is an interesting problem - now I'm curious!
      I know Mustangs have this issue and the fix there is to lower the fluid level a bit.
      Check the surface of your master cylinder where the cap sit and make sure that it's level. I've seen aftermarket cylinders where the surface wasn't level and it was leaking. Might have to take a file to it to level it out.
        For your rear brakes, Are you running drums or disks? I think the 98 to 02 master would be set up for a disk/disk system. Don't know if this would cause your leaking problem.
        88 Country Squire
        86 Colony Park, non-op'd
        89 Mark VII LSC, non-op'd
          I will have to check for flatness. In my head either the cap or reservoir surface itself is worn out/damaged in a way to create this weepage.
          This was not always the case with the car. Seemed to only start after the 5 speed swap. Only thing that comes to mind is that the fluid now gets more thrown around while banging gears......
          Good observation. I failed to mention that I also have rear discs on the vehicle in question.
            haven't had that on mine, but it could have some plastic flash around the opening or something
            just watch what sort of rubber you use. Lots are not compatible with brake fluid and will turn into a swollen mushy mess.
              True. Even a thin nylon, plastic etc would suffice to use as a shim up under the primary gasket.....
              I'll have to give it a real good look to see whats up.
                Great thread good info thanks
                  plastic would probably work. Got an old brake fluid bottle to cut up?
                    Yes! That is a good idea...It holds brake fluid after all.
                    I did cut two thin spacers up out of some thin plastic already and will try those out with a different cap and gasket I have on hand after inspecting the caps mating surface on the reservoir.
                      Checked out the reservoir mating surface and it is all smooth. While rubbing my finger around the mating surface I can feel a slight dip in a spot or two but it is a very smooth dip.
                      I had another cap and gasket which I slipped a thin plastic spacer behind the gasket and will see how it goes.
                      Definitely a lot tighter going on now.
                      The picture below shows how wet the top gasket gets.
                      Pulling the gasket out revealed just as much fluid.
                      I believe it was just not a good seal causing the fluid to slip around the gasket and then drip out of the cap.
                      I will update when there is an update.
                        I think this is good now. No weepage after this last 250+ mile outing.
